Keihin fcr mx flat slide carb swap
Old Nov 10, 2014 | 05:56 PM
  #41
113moro's Avatar
Looks like the fcr 35 will fit
but it will be tight the only hassle I can see is that you will have to
take it in and out a lot of times getting the jetting wright
I might go the easy route and give bill Blue a call and give him some business and get one of his mikuni carbs already set up for the Klx
the fcr and the fcr mx are two different carbs very different in Physical
size I would of liked to use a fcr mx I have worked with them a lot
great carb but the mikuni flat slide pumper will be a lot better for the
klx than the stock carb
Back 2 square one
Bill 113moto
Old Nov 10, 2014 | 08:28 PM
  #42
Richard Avatar's Avatar
Old Nov 10, 2014 | 09:27 PM
  #43
113moro's Avatar
I want to see if you can use the mrege racing adjustable leak jet and the scarry fast power now on the fcr35 if so I might go that way,i will have to keep a eye out on ebay for one.
Old Nov 10, 2014 | 09:30 PM
  #44
Originally Posted by zomby woof
If somebody decides to try a TMXX, I've done a lot of set up on these carbs, so I may have some useful info. The guys I ride with actually prefer the Kehin PWK over the TMXX for anything other than WOT/MX racing. I have an RB modded TMXX on my Husky that works very well. I also have a spare TMXX, and a 38 Lectron just sitting in a box. Hmm.
I've seen the TMX, but not the TMXX. Are they working on a four stroke or two stroke. From the small amount I saw they were rather temperamental kart carbs, but I have no experience and you do. The PWKs are available for a fair price though and if they're a good possibility it would be worth looking into. Do they use them on any four strokes?
Old Nov 10, 2014 | 10:18 PM
  #45
I've not really looked at the whole FCR situation and how it fits to the KLXs, but a simple flange manifold and a piece of radiator hose with the proper ID made a dandy manifold on my old Sherpa S. This has long been the method to fit spigot carbs in place of flange mount carbs on bikes. The manifold butts up against the carb and all is held by the hose and clamps. So make a longer intake manifold.
If the air boot can be worked with, this is a possibility moving the FCR, rearward. If I remember right, the FCR is shorter than the stock carb. If so, the lengthened manifold would be a distinct possibility with some turning of aluminum, some sawing to shape the flange and drilling to suit the bolt pattern. None of it is difficult or time consuming. It just takes a piece of billet aluminum or some flat stock, tubing and TIG work. This would also move the bolt head away from the starter. Who knows, might just eliminate the frame interference issue, too. Move the carb back with a longer manifold if it is possible.
Just some thoughts from past experience.
In the video, did the guy who did the carb on the KLX do much work to jet it or if that was just how it was to start with ball park jetting and setting?
Old Nov 11, 2014 | 03:58 AM
  #46
Someone would have to try and contact the guy who did the video.. It sounded like he's got an off idle hesitation
Old Nov 11, 2014 | 04:30 AM
  #47
Lots of FCR35 jetting info here, starting with post #4..
https://www.kawasakiforums.com/forum...e-issue-35994/
Old Nov 11, 2014 | 03:50 PM
  #48
113moro's Avatar
It is a drag that the fcrmx wont fit on my klx250sf
but I am over it now, my wife says that I would be Pussin out if I just blot on a mikuni ready made flat slide so now to find a fcr 33 or 35 and go from there
this carb now will get set up for a drz 400 or a dr650
Life goes on
Old Nov 11, 2014 | 04:00 PM
  #49
113moro's Avatar
This is what I need fcr 33 35 I would rather have the 33 over the 35
I am sure one of you dudes out there has one sitter around ya want to get rid of
Bill 113moto
Old Nov 11, 2014 | 04:10 PM
  #50
113moro's Avatar
This is bill Blues Mikuni flat slide pumper that he makes up
A 33 bored to a 34 and he makes the adapters
Bill Does a *** woopen job on this carb
My hats off to ya Bill
Bill 113motoName:  billbluemikuni_zps420fcbf7.jpg
