IMS tank install 2018 version
Old Jun 22, 2018 | 11:00 PM
Dragon351's Avatar
Default IMS tank install 2018 version
First issue:
the “Reserve” and “On” lines exiting the bottom of the tank (see photo) won’t go in the IMS tank. Are those plastic tips necessary?
Are the plastic tips necessary. These lines will not fit all the way in the IMS tank. They bottom out before the threads reach the imbedded nuts in the under side of the tank.
Second issue:
no way I can get the rubber grommet off (where the rear of the tank meets the front of the seat) without breaking it or cutting the metal ear on the old tank.
Third issue:
The instructions… “the stock tank has two hoses connected to the bottom of the tank, the California models have three; none are used with the IMS tank”… what? There only are the two gas supply lines on the bottom of my tank. They go to the petcock.
Fourth issue:
The instructions: “to get a proper seal, the stock o-ring on the small threaded brass fitting (it has the standpipe) must be replaced with the 2x8mm o-ring provided”.
”standpipe”? Threaded brass fitting? The only threaded brass fittings are the supply lines that exit the bottom of the tank, neither will accept the supplied o-ring.
Fifth issue:
What's a "separator"?
Old Jun 22, 2018 | 11:09 PM
Dragon351's Avatar
ok, the plastic casting just isn't that clean at those entry points... I just had to man up and jam them in... gentlemanly.
One down
Old Jun 22, 2018 | 11:12 PM
RaceGass's Avatar
You really need to contact ims tech dept and ask those questions. Really don’t you think so ?
Old Jun 22, 2018 | 11:26 PM
Dragon351's Avatar
Issue two: I just tried prying it apart (in a gentlemanly fashion) and the inner metal tube/core started to protrude, so I yanked it out and then could squeeze the grommet/dampener out.
Two down
Old Jun 23, 2018 | 02:24 AM
Dragon351's Avatar
yup...
Old Jun 23, 2018 | 02:26 AM
Dragon351's Avatar
Friday night big fun...
Saturday she might run
Old Jun 23, 2018 | 10:32 PM
A.J. Haun1005's Avatar
Mine installed really smoothly.. but didnt have thoee 2 lines you posted up. Just putting on the fuel pump and capping the 3rd line.
Old Jun 25, 2018 | 12:00 AM
Tacoma660's Avatar
Off topic question...... you think it would be possible to retro fit the stock gas cap onto the ims tank? I'd love to have a bigger tank but dont want to loose the locking feature
Old Jun 25, 2018 | 05:12 AM
RaceGass's Avatar
I had put a little (very little) thought into making a locking cap out of something. A quick fill flange (this isn’t the one ims sells) would need to be done, which would involve cutting the plastic neck out of a ims klx tank. And that’s where my thinking came to a halt
Dash8
Mar 8, 2016 07:09 PM
tb865
Feb 17, 2014 08:25 PM
DYNOBOB
Feb 5, 2014 03:00 AM
Lilyboy
Feb 23, 2013 03:02 AM
RaceGass
Jun 19, 2012 07:46 PM
