Help from the suspension gods.
Old Jul 27, 2017 | 10:13 PM
Opticlicker's Avatar
Default Help from the suspension gods.
09 KLX250s 130 geared up, can someone tell me an idiot proof instructions on how to set the front forks and rear spring please? If you have a setting that would work that would be great!
Thank you.
Old Jul 27, 2017 | 10:19 PM
durielk's Avatar
Sag should be 30-35% with you on it. Look at the manual and google sag, there may be gobs of ytube videos too!
Old Jul 28, 2017 | 12:18 PM
outrecording's Avatar
Not sure if this is what pure looking for, but I followed Bruce's instructions here:
https://sites.google.com/site/brucessuspension/suspension-knowledge-base/adjusting-suspension
Old Jul 28, 2017 | 01:57 PM
https://sites.google.com/site/bruces...ing-suspension
Yep, as far as excellent, understandable, general suspension knowledge and adjustment goes, Bruce's Suspension info is about as good as it gets. It helps you really understand why you're performing certain steps and the results you should get instead of just twisting ***** and clickers.
OP, if your KLX is stock, you can use the manual's instructions as a good starting point for the number of clicks on the fork and shock to suit your weight, riding style, terrain, and preference. Between Bruce's Suspension guidance and the manual, you should get something workable. However, the fork in particular usually requires revalving to get really good results. At your weight, the stock fork spring weight will probably be satisfactory.
cegusman
May 26, 2012 12:24 AM
BouncingRadical
Apr 25, 2009 11:15 PM
Sid Post
Dec 16, 2007 03:32 PM
cool change
Nov 15, 2007 01:43 AM
Zwild_m30
Mar 7, 2007 07:53 AM
