Help!! Klx 250
Old Jan 19, 2015 | 08:17 PM
Does it run at all? What putbinoot said above is another possibility. Have you messed with the keyed ignition switch?
Old Jan 19, 2015 | 11:20 PM
durielk's Avatar
Yes, explain to us, when it was running & how it ran. What did you do to it just before it stopped running?
Old Jan 21, 2015 | 04:45 AM
Lepo's Avatar
Default Klx 250
Originally Posted by putbinoot
When you say you are not happy with spark if you take the plug out and hold against engine case are you getting a consistent spark, there is a 100ohm resistor in the ignition if that is not seen then you won't get a spark , I cut my damaged ignition out the circuit but had to add in the resistor to get bike to fire. Have you had an auto electrician check the ignition circuit and can you get the plug wet with fuel so you know that fuel is getting there
The spark seems to be very faint and seems to be firing too much if that makes sense, instead of firing just at TDC it looks like it is firing constantly. The ignition has been pulled apart by previous owner but bike was running after I installed another CDI just not well, it used to start when it was cold and then not once it was hot now it will not even pop even with Aerostart. What wires and what size resistor are you supposed to install maybe that will smooth out the spark.
Old Jan 21, 2015 | 08:06 AM
putbinoot's Avatar
If you are getting a spark I would say the resistor is ok, if it was not you would not get any spark. i also had what looked like a poor spark which was the result of the spark gap being to small mine should have been set at 0.7mm-0.8mm make sure your plug gap is set correct. Does the plug get wet with fuel if you try to start it for to long.
bcwilliams
Oct 27, 2013 08:10 AM
adrian2779
Apr 7, 2012 10:28 PM
Cropduster21
Nov 28, 2007 04:36 PM
Bad Bear
Jul 24, 2006 12:59 AM
Icantrideabike
Jul 1, 2006 09:18 AM
