Help with adjusting Front Brake KLX 250H' 06
Old 09-13-2010, 10:17 AM
Pepe72's Avatar
Default Help with adjusting Front Brake KLX 250H' 06
Hi folks, was hoping to get some assistance with my front brake adjustment. Im finding I'm needing to bring the brake lever in alot more and apply more pressure to apply some effective braking.... do I need to bleed it? Pads are fairly new. Any help greatly appreciated!
Pepe
Old 09-13-2010, 11:49 AM
MaverickAus's Avatar
To bring the lever in adjust the screw on the lever to suit. If you want more effective braking you need a stainless steel brake line
http://bandbcyclerestorations.com/page_2.html
bottom of the page
Old 09-13-2010, 03:35 PM
FlyingFinn's Avatar
More, compared to what? Compared to earlier or compared to some other bike?
Mushy brake lever like that is usually a sign of air in the brake system or maybe a stuck caliper.
Before upgrading the line (SS line is an upgrade) take apart/inspect/re-assemble the caliber and very carefully bleed the brake line.
Mikko
Old 09-14-2010, 12:17 AM
TexasKawai's Avatar
What color is the brake fluid? If it is not clear but dark brown it may just be time to bleed the brake with new fluid. This will be the cheapest and most easy thing to do.
Old 09-14-2010, 02:51 AM
fluid change is in your manual, but I prefer more fluid changes. as mentioned, lines are a key item if you are having issues with fade. The flex of the stock lines contribute to the mushy feeling
Do the fluid change and proper bleeding first to see where this ride is at. good luck
Old 09-14-2010, 02:44 PM
I've not changed the fluid ever in 14,000 miles. They work perfect!
Old 09-17-2010, 08:20 AM
Time you did it Deej ol' chap
Old 09-17-2010, 01:45 PM
If its not broke.......
Pepe72
04-04-2014 03:02 PM
Pepe72
01-13-2011 02:14 AM
Pepe72
03-30-2010 04:57 AM
Sid Post
04-22-2008 04:26 PM
mikem1965
03-04-2007 08:35 AM
Quick Reply: Help with adjusting Front Brake KLX 250H' 06
