Headlight bulb replacement
Old Aug 2, 2016 | 12:51 AM
Berzerker's Avatar
Question Headlight bulb replacement
I am a new rider since Sept 2015 and own a 2011 VN900 Classic SE. I want to upgrade my headlight to a brighter bulb without having to beef up wiring harness for possible heat damage. Stock lamp is terrible on night rides.
Any suggestions?
I am looking at the HELLA H4 100/80w.
Thanks,
B13
Old Aug 2, 2016 | 01:29 AM
Matt88-8's Avatar
I highly recommend you don't go to I higher wattage bulb with stock wiring and housing. You will melt something.
How about led headlight bulb or auxiliary lights.
Old Aug 2, 2016 | 02:35 AM
Berzerker's Avatar
Thanks Matt88-8
Old Aug 2, 2016 | 07:42 PM
taxonomy's Avatar
Any suggestions?
Thanks,
B13
Do you know that this is the KLX250S part of the forum? This is a small dual sport/dirt bike, not a cruiser.
You probably want to be somewhere over here.
Kawasaki Vulcan Models - Kawasaki Forums
Old Aug 3, 2016 | 12:18 AM
NorCalKLX's Avatar
I run a Cyclops led conversion with the high low beam option. Works great! Not sure if they still honor the advrider coupon but it saved me 5-10 bucks which was cool. It's totally plug and play so if you don't like it nothing gets screwed up if you go back to stock.
Old Aug 3, 2016 | 05:43 AM
Klxster's Avatar
Hey a VN900 is a pretty cool looking bike..
Replace your VN's headlight assembly with a KLX250S headlight assembly and report back with pictures - yeah we'll all be ROFLOL, but we'll have some ideas for you..
Old Jun 25, 2021 | 02:05 AM
Neanderthal's Avatar
I have this exact LED bulb(s) in my Yamaha FZ1 and just installed one in my 2018 KLX.
https://www.superbrightleds.com/more...1940&year=2018
Very, very happy with them! I wasn't able to re-use the rubber boot at the rear of the bulb, but it's waterproof so if any water did find it's way there, no biggie. After you install any new bulb - re-check the headlight aim. A good spot is inside your garage with the lights off. There is a spec in the user manual to where the light should be aimed.
Savagekilla
May 16, 2008 10:22 PM
wmlkaw
Aug 2, 2007 06:29 PM
07ex500r
Ninja 500R
Aug 1, 2007 08:02 AM
GC
Ninja 500R
13
Mar 6, 2007 06:43 AM
EMS_0525
Jan 4, 2007 10:12 PM
