Handguards for a KLX250S...
Old Mar 4, 2013 | 12:27 AM
  #61
durielk's Avatar
How, what, & where does that bent alloy triple mount connect to the bike. The inside end of mine I have tied to the handlebar with 1/2" extra standoffs & I don't like that.
Old Mar 4, 2013 | 11:06 PM
  #62
Red Brigade's Avatar
It bolts onto the yoke. You need to replace the current bolts with longer ones. You an see it in some of the photos.
Old Mar 11, 2013 | 01:27 AM
  #63
Jage's Avatar
Red, do you remember what size bolts you bought to replace the existing ones? I looked at a parts schematic and it said that they're 8x40 bolts, but I'm not sure I know what that means... How does that convert into something that I would buy at a hardware store?
Old Mar 11, 2013 | 03:39 AM
  #64
I'm sorry I don't. I took one of the original OEM bolts from the bike and took it to the parts store and asked for one 1/2 inch longer. They found the bolts in the back. It was pretty easy actually.
Old Mar 11, 2013 | 04:30 AM
  #65
BillMoore's Avatar
I installed a set of the Moose Racing handguards on both my KLX250S and my wife's CRF230L this weekend. The install was fairly easy (would have been easier if I had read the instructions first). Biggest hassle was getting all of the cables routed and controls aligned.
These handguards seem beefy enough to do the job, and at a price that didn't break the bank...
Old Apr 3, 2013 | 12:23 AM
  #66
Oreganic's Avatar
Originally Posted by PSUdude85
I had a similar problem with mine, I had since covered the brake line in electrical tape since it rubs the mount during suspension articulation, and also re-routed the clutch cables to go above the guard.
____________________
I had the same brake line issues as Lotrat & PSUdude85. I love how the BarkBusters look and perform, but you really have to "thread the needle" to get these things on. I must have fidgeted at least three separate times to get them where I wanted them. I had to move the brake line to the outside (front) of the clutch cable and wire harness to keep it from rubbing and catching on the BarkBusters during articulation. Now the BarkBuster mounting hardware is above the wire harness, below the clutch cable and it just barely grazes the brake line. The Brake line is also wrapped in electrical tape for a little extra protection. Finito...
Old Apr 12, 2013 | 03:11 AM
  #67
GBAUTO's Avatar
Default Powermadd
Just wanted to post up some pics of the Powermadd handguards I installed. I modded the mirror position to get a bit more crash protection-they are acceptable(decent even compared to some of the sportbikes I've been on). I ground down some of the R/H oe mirror mount to make it fit properly. They have been crash tested with very good results...
Attached Thumbnails Handguards for a KLX250S...-handguards-001.jpg   Handguards for a KLX250S...-handguards-002.jpg   Handguards for a KLX250S...-handguards-003.jpg   Handguards for a KLX250S...-handguards-005.jpg
Old Dec 27, 2013 | 11:52 PM
  #68
GTackett's Avatar
I see the issues with the clutch cable and the front brake line on the left side, but what about on the right side where the brake line comes out of the front master cylinder?
I bought a set of MSR handguards and they appear to have similar bends/clearance as the Cyclar.
Are there any handguards that clear the brake line bolt on the right side? Or do you have to rotate the guards above or below?
Thanks...
Old Dec 28, 2013 | 02:55 AM
  #69
1994klr250's Avatar
I went with the HDB hand guards on my 06 klx. They match the bike perfectly. Can't wait to test them out in the spring as I put them on too late in the year.
I got the optional mirrors on each side.
Old Dec 28, 2013 | 03:21 AM
  #70
durielk's Avatar
Those HBD units look like they have more room for the levers, I like them. I'm getting them next time. Where you get them?
The post with the red bike, it looks like you installed them with the bend up. Most have it down, that may work better, post a report after you crash please (hope it is next year at least).
That sounds like I am kinda mean? sorry.
