Guy with the 250 with the sleeve?
Old 06-21-2007, 09:03 PM
kgwld1's Avatar
Default Guy with the 250 with the sleeve?
I know someone on here had his 250 sleeved to a 331 how it go and who did the work? can he included all the parts? let me know
Kevin
Old 06-22-2007, 01:18 AM
2k1w=no$'s Avatar
Default RE: Guy with the 250 with the sleeve?
The guy that had the 250 jug sleeved is name is marty, he doesn't come around the forum any more. Blue Bill did the work for him(the guy that is boring the 33mm mikuni's). From what I hear the work was top notch and the bike runs awsome. I don't think anyone else on here has done this but someone else is getting it done from some where else.
Old 06-22-2007, 03:04 AM
mmatz's Avatar
ORIGINAL: kgwld1
Kevin
I have this Thumper Racing 340cc big bore kit that one of you guys really needs to buy and install. It is new and includes cylinder, piston, rings, pin, clips and gaskets. Sold my KLX but I would bet this is just what this bike needs to make it rip.
Old 06-22-2007, 01:33 PM
mmatz, you got a PM
Old 06-22-2007, 01:52 PM
mustang's Avatar
+1 on the Thumper Racing kit! It will absolutely transform your bike. I have 650 miles on mine so far with no problems whatsoever. With everything provided in the kit, it was simply a matter of swapping parts. However, all of the big-bore kits are good and will provide similar results.
As for Bill Blue, he is a first-rate guy that does top-notch work. It's rare to find someone who cares as much as he does that you are a satisfied customer.
The KLX250s cylinder only differs from the 300 cylinder in bore diameter- every other dimension is the same. Talk to the manufacturers, but you should have no problem using your stock cylinder with any big-bore kit.
Whichever route you choose, I think you'll be very impressed with the results.
jeffreytucker
04-14-2015 08:06 PM
671brandon
01-19-2015 08:32 AM
Feral Donkey
12-16-2010 10:14 AM
Icantrideabike
07-01-2006 09:18 AM
SpaldingSpeed
08-19-2005 09:23 PM
Quick Reply: Guy with the 250 with the sleeve?
