Gas tank only works on reserve?
I bought an 06 used w/ only 800 miles. The previous owner had to have the carb cleaned after it sat for a while and ever since, the bike will only get gas when the petcock is turned to reserve? Any clues? I have not torn into it yet, but suspect it is something simple like a clogged screen, or improper re-assembly.
Does the tank have enough gas in it for the primary pickup? If it does, you may need to pull the gas valve and give it a good cleaning. Here is a diagram.
Looks like A & B are the "on" and "reserve" outputs. I have to say that ours looks nothing like the old bike pickups. So this is where my understanding ends on how to clean it. Good luck.
at first i thought same. But if hoses are crossed that means he can only get gas in on position. I hate thinking backwards! more than likely theres a clog somewhere. Empty tank and check petcock and lines back to tank. Good luck.
Oh yeah good call lol,, oh well I tried
I hate thinking backwards to lol
Well kink this and kink that, someone might pinch a tube .I am being as polite as I can without loosing an integeral part of my anatomy.just being an old arsehole crf thats how we learn.
