First Breakdown
Old Mar 1, 2008 | 01:33 PM
Davebert's Avatar
Default RE: First Breakdown
We had a similar issue with the wifes KLX shortly after we bought it. The battery went dead. To make a long story short, I pulled the left side cover and noticed a connector was unplugged. I plugged it back in and all was fixed. We think the last owner may have experienced the same problem so he charged up the battery and traded it in. His loss, our gain!
db
Old Mar 1, 2008 | 01:39 PM
ORIGINAL: vlodpg
Is there anything like a grease or silicone spray that we can use on connectors that will prevent corrosion but not effect the connection?
here ya go.... dielectric grease... Dielectric grease is a NON-conducting grease that seals out moisture and
therefore prevents corrosion on electrical connectors.
Old Mar 1, 2008 | 01:52 PM
Davebert's Avatar
We used that all the time when I was working for the JEEP dealership. Good stuff.
db
Old Mar 1, 2008 | 01:58 PM
tremor38's Avatar
Yup, I use silicone dialectric grease for quite few things.
Old Mar 1, 2008 | 03:51 PM
2k1w=no$'s Avatar
ORIGINAL: Davebert
db
I seem to remember that some others had the same problem with brand new bikes off of the showroom floor. Battery was dead by the time they got home and found the plug disconnected.
Old Mar 1, 2008 | 05:16 PM
warski's Avatar
I live in the desert, the only thing I have to worry about is "dry rot". All of the "streams" I cross are "arroyos". I wouldn't mind getting the bike wet once in awhile...
Old Mar 1, 2008 | 07:38 PM
rkutzner's Avatar
A while back I remember everyone fixing that problem with tie-wraps, including myself ! I greased it and smothered all those backside holes with rtv.
Old Mar 1, 2008 | 10:50 PM
  #28
Jetboy950's Avatar
Okay,Guys and gal's, Here is the picture of the connector after fixing the problem, If any one is interested they can unplug the connector then start bike and then dissconnect battery ground cable bike will quit running. You can also plug in then start and dissconnect ground cable at battery and bkie will run but lights will be very dim!! Note also check positive cable where runs from starter relayto battery mine had rubbed between fender and frame and you see the results. Thanks Dave
Old Mar 1, 2008 | 10:53 PM
  #29
Jetboy950's Avatar
Got ahead of myself.
[IMG]local://upfiles/3524/8D2800E24B8A4D12BFDCF4A7D29BB08D.jpg[/IMG]
Old Mar 1, 2008 | 10:55 PM
  #30
Jetboy950's Avatar
Battery cable
