Engine oil sight glass... cracked
Old Jan 17, 2017 | 11:52 PM
Abramsgunner's Avatar
Default Engine oil sight glass... cracked
So I went for a ride with my brother Sunday... somehow a rock snuck up between the brake lever and cracked the oil sight glass.
Looks like it pushes in from outside?
2009 KLX250S
Old Jan 18, 2017 | 12:08 AM
GBAUTO's Avatar
Yeah, it should be removable. I see that the replacement part is available and about $15 You may need to get to the backside of the glass to get it out so the r/h cover may need to come off.
Ok-looks like these things fit like a freeze plug so once you have been able to pry/remove the old shell I would put the new part in the freezer to shrink it and be very easy in tapping this thing in -place-they like to break.
Old Jan 18, 2017 | 12:33 AM
Good point, didn't think about the freezer. I'm gonna try a couple local dealers tomorrow, and if they don't have one I'll order it up. Thanks for the input.
I'm amazed a rock could sneak up in there...lol We did hit several sections of gravel road that had the perfect size stones.
Old Jan 18, 2017 | 03:20 PM
Yeah it is unusual. I've always been surprised it doesn't happen more often on off road machines that have oil sight glasses like this. Even working at a motorcycle shop as a mechanic part time for 15 years, I think I can recall seeing only one come in. Apparently it's tucked away better than we think...LOL.
Old Jan 21, 2017 | 01:10 AM
Done.... turns out it is a very simple fix, press fit, but there is a rubber ring of some sort around the outside. Just dig out the old one with a small screwdriver, pop the new one in the freezer for a few, coat it with fresh oil, press it in..... It slipped in easily with firm finger pressure.
None of my local dealers had one (3 different shops) but I got one shipped for about $17 total.
Part No. Kawasaki 52005-1009
PS: Don't think I won't be checking every ride for the next 5000 miles or so.....lol
seth6025
Dec 16, 2012 10:13 PM
cjcrashesalot
Nov 20, 2009 03:45 AM
gjkydy
Nov 18, 2007 03:15 PM
smurph
May 8, 2006 02:13 PM
westcan
Apr 21, 2006 02:29 PM
