Cut chain too short- help
Old Apr 2, 2007 | 12:52 AM
mikem1965's Avatar
Default Cut chain too short- help
Cut chain too short- can I add back an original link or is it better (safer) to use 2 master links??
also while on the subject- why is an o-ring chain considered better??
Thanks
Old Apr 2, 2007 | 02:59 AM
mole's Avatar
Default RE: Cut chain too short- help
I am by no means a chain expert, but this link had a ton of stuff about chains in general:
http://faq.f650.com/FAQs/GeneralChai...s%20and%20Tips
Old Apr 2, 2007 | 03:35 AM
Are you sure you put the adjusters all the way back to 1?
Old Apr 2, 2007 | 03:46 AM
lcpl0331's Avatar
i've added links before on my kdx and on my son's xr250. i never had a problem doing it. it's not the safest thing to do but your stuck now so unless you want to buy another chain it's your only option.
Old Apr 2, 2007 | 04:16 AM
mikem1965's Avatar
yes the adjusters were at 1- and I was about 2 links short- i added 3 links with another master and the adjusters are now at 5
Old Apr 2, 2007 | 06:47 AM
motoguy128's Avatar
You can use another master link along with other links. It's not the best set-up, but not really a big deal.
An o-ring chain contains seals that hold grease in the rollers. A chain is esesntially a series of steel bushings which spin around the steel pin that holds the links together. A non-o-ring chain needs more frequent lubrication since the lubrication is not held in the rollers. They are lighter, and have less friction when they are properly lubed. They don't last as long. O-ring chains are more expensive, butlast longer, and require less maintenance (lube is only to prevent rust and lubricate the surface of the sprockets.)
I accidentally ordered a nono-ring chain when I went +3 on hte rear. It's worked fine so far, but I don't put a lot of miles on the bike. I'll go bakc to an o-ring next year when this one wears out.
zzrotceh
ZZR 600
Feb 1, 2011 06:23 PM
CousinLarry
Mar 18, 2010 04:45 AM
eas
Mar 11, 2008 07:01 PM
JB1
Mar 27, 2007 10:51 PM
Ninja250gurl
Sep 10, 2006 04:30 AM
