Black Clarke Tank
Old Jan 17, 2008 | 03:47 PM
  #41
ZX1100F1's Avatar
Default RE: Black Clarke Tank
My bet is that back in the 70's you weren't as **** as you are now and most things probably looked OK to you.
You'd likely throw darts at that old grey Baja tank if someone handed it to you now.
Nothing personal, we're all getting a bit more spoiled now I suspect.
I remember watching some of them way cool old TV shows back then...............I can't sit through 5 minutes of one now........except CHiP's that is.
Old Jan 17, 2008 | 04:27 PM
  #42
gerrynolan's Avatar
ORIGINAL: ZX1100F1
Very true, and....."Pretty is as pretty does" I'm more concerned with the leaks. As long as you get a good one that doesn't leak I guess it don't matter too much. But...That tank looks pretty bad Man.
Old Jan 18, 2008 | 12:51 PM
  #43
tremor38's Avatar
ORIGINAL: gerrynolan
[/quote]
Aw, you're just a 'hater' Jerry
Old Jan 18, 2008 | 07:46 PM
  #44
stellar_d's Avatar
ORIGINAL: HeavyFuel
Maybe some of you guys should stick with the stock tank. It's smooth and shiny and you can keep it all waxed and purty!
Nah I'll go for it....I have to get a new one anyway so I'll give the clark a shot. Probably will have to order up soon before they start getting tons of orders in and some shotty ones slip through the cracks.
Old Jan 18, 2008 | 09:11 PM
  #45
TypeSH's Avatar
If you aren't going to care about looks then why not go with the Acerbis tank? Sure it is ugly but it holds more and is almost the same price.
Old Jan 19, 2008 | 07:27 AM
  #46
vlodpg's Avatar
There is a stock tank on eBay for $35 buy it now!
Old Jan 19, 2008 | 02:13 PM
  #47
HeavyFuel's Avatar
ORIGINAL: vlodpg
[sm=bounceybounce.gif]
Old Jan 20, 2008 | 12:27 AM
  #48
4SEVEN3's Avatar
I had a idea on the Acerbis tank, chime in if you think Im nutz!
Picture this....
A fuel hose comming off the petcock inside the tank.
Have a Y connector, then two lines going toboth sides of the tank. Use something on the end so that they pick up from the bottom, that way you get all the fuel from the right side of the tank.
Im sure someone can improve on that. Personally Im really liking the Acerbis tank. I couldnt give a crap if it's ugly, its got range!
Old Jan 20, 2008 | 10:26 AM
  #49
tremor38's Avatar
I remember somebody posting that they have done that already...worked like charm. I don't remember if I read about it here or at the Advrider site.
ORIGINAL: 4SEVEN3
Picture this....
Old Jan 20, 2008 | 01:01 PM
  #50
4SEVEN3's Avatar
Interesting Tremor. Ill have to do a little research. The idea came from messing with model airplanes long agao.
