Anyone with experience building motors - advice plz?
Old Mar 16, 2009 | 01:02 PM
CousinLarry's Avatar
hahaa... East!
Nah, worked all day, stopped at about 11:15pm last night. Just woke up at 8:30am, going in for round two!
Old Mar 16, 2009 | 02:05 PM
ddt1972's Avatar
You should be able to just lift it enough to get it in there.
Old Mar 16, 2009 | 02:15 PM
keep us informed
Old Mar 16, 2009 | 02:22 PM
Bummer man. Is that thing pressed in? Don't try and grab onto it with vice grips, it will probably scratch it up. Maybe a rag in between the pliers. Good luck man.
Old Mar 16, 2009 | 02:39 PM
al.b's Avatar
Default bolt sleeve
hi larry
i dont want to be a pisser but i was looking at your photo
and the bottom left bolt hole looks like the top right hole.
does it need a sleeve as well? i'm not a pro but it just looked
like the top. i looked in the manual, but i did not see a sleeve
on the top or bottom. call bill just to be sure. like i said i dont
want to be a pisser but better safe than sorry.
al.b
Old Mar 16, 2009 | 02:41 PM
I was wondering about that too. It seems like if you are going to have a pin alignment, you really have to have two.
Old Mar 16, 2009 | 03:09 PM
WestOzKLX's Avatar
We'll assume he already has the one sleeve on the head he installed on the 350 kit. It's quite common when separating 2 parts that have the collets for alignment that the collets end up on different parts. They aren't male/female and thus fit either locating hole. I'm pretty sure he only has to fit the one off the 250 barrel in the photo, although it will be come plainly obvious when he removes the head.
Old Mar 16, 2009 | 03:42 PM
Just put it in, putting everytthing back together now. And the other sleeve was in the head - no worries.
One question about the jetting - I have an FMF kit. It's a KLX250S with an FMF full exhaust, airbox lid removed, and foam filter. Current setting is stock pilot, 128 main, C clip at 4th notch.. I think the mixture screw is 2.5 turns or so out. I think the mixture screw is 2.5 turns or so out..
My only other bigger jet I have is a 132. Should I try the 132? Or stay with the 128 and richen it up a bit?? If it matters much, I'm at sea level - 3k ft at the most.
Kinda lost on that one..
Thanks
Old Mar 16, 2009 | 05:06 PM
Glad you got it back together.
Old Mar 16, 2009 | 05:31 PM
cliffsta's Avatar
I'm no expert but with all your mods, including exhaust, I'd definately run that 132 main. I'm running the 128 main and 2.5 turns out with a stock filter and stock exhaust, all I did was pull the snorkel. By increasing the displacement, more air and fuel are needing to be combusted. Laws of physics will pull in the extra air, but you'd need to step up the jet size.
Like I said, I'm no expert, but that's how I've come to understand it.
