Acerbis Tank install question
Old 02-20-2009, 10:45 PM
azdriver's Avatar
Default Acerbis Tank install question
I'm in the process of fitting an Acerbis tank to my 09. The petcock that comes with the Acerbis tank is really hard to turn from off-on-reserve. I tried slightly loosening the screws near the valve and also working the valve some in the hope of loosening it up but it does not seem to be working. I don't really want to open it up for fear of causing a leak- once I get some fuel run through it do you think it will loosen up??
As it is with this tank the petcock is in a less accessible place than stock and it would not be too cool to have to quickly switch it over from on to reserve in a traffic situation, etc.
If anybody has had some experience with the Acerbis please let me know!
Jim
Old 02-20-2009, 11:38 PM
azdriver's Avatar
Default nevermind!
got some gas flowing through it and the petcock has loosened up
Old 02-21-2009, 11:00 PM
Dipstik_09's Avatar
How was the fit on the '09? I was thinking about getting one for mine but I've heard people have issues with seat fit. Pics please.
Old 02-22-2009, 05:33 AM
redpillar's Avatar
I have fitted the tank successfully to mine. I ended up using the stock petcock and it works great. Here is a link to the installation. read the whole thread. It is a bit of work but really worthwhile. If you want to do it and have questions PM me.
http://www.advrider.com/forums/showt...02#post6856102
Old 02-22-2009, 04:48 PM
azdriver's Avatar
Red, I saw that write-up and it was helpful. My Arctic Cat pump is on order. You say you used the stock petcock but it doesn't really show in the photos how you accomplished that. If you could tell us how you did that I'd appreciate it.
Old 02-23-2009, 03:58 AM
punkenduro09's Avatar
i just deal with it, try to make sure never to hit reserve.
Old 02-25-2009, 09:07 PM
redpillar's Avatar
I made a fitting to go into the tank.
It is made of standard fittings, I ground the one that goes into the tank so it would fit through the hole. I made the aluminium plate and threaded the fitting through it and used gasket maker to seal it to the tank.
Then I ran a fuel line fromt he tank to the pump inlet and then to the stock petcock which I ended up mounting on the outside of the bracket and I think I actually spaced it out with a washer to clear the tank a bit better.
You have to plug one of the outlets of the petcock so there is no reserve but you can see through the tank which in my opinion is better than having a reserve.
Hope this helps.
mcrider1959
05-10-2022 05:45 PM
xxaarraa
01-28-2013 01:57 PM
horizonod
12-18-2008 07:28 PM
cwgoff
03-27-2007 06:24 PM
EMS_0525
01-27-2007 09:42 PM
Quick Reply: Acerbis Tank install question
