09 KLX250s clutch/transmission issue after shift star change
Old Mar 27, 2021 | 05:34 PM
phil_r's Avatar
Default 09 KLX250s clutch/transmission issue after shift star change
After waiting over 6 months to get a new shift star at my LBS, I am having clutch issues now that I have it installed. With everything all buttoned back up, I can shift through all the gears fine with the back wheel off the ground, but the clutch doesn't engage in any gear and the bike launches when I try to shift into first to move forward. Same happens in all gears.
It sat with no oil in it for the 6 months. I thought maybe the clutch disks were seized together but that doesn't seem to be the case when I remove the cover and take the pressure off the springs.
I'm at a loss on something I am sure is simple...
Old Mar 27, 2021 | 09:16 PM
Brewster's Avatar
If you removed the clutch, there is a washer under the clutch hub nut that is NOT flat and must be installed concave side towards the clutch hub.
# 92022 ( I think)
https://www.kawasaki.com/en-us/owner...S-_-PARTBUCKET
Ride on
Brewster
Old Mar 28, 2021 | 09:28 PM
phil_r's Avatar
I didn't take the right side apart until after I put the left side back together and realized the clutch wouldn't engage. I'll take the right side off again though and take a look. Any other ideas out there?
Old Apr 1, 2021 | 02:53 PM
phil_r's Avatar
Solved: Clutch got too hot and one pad is seized to a plate. Lesson learned. Getting very stuck in mud solo is a bit of an expensive experience...
CodyShipley26
Jul 13, 2018 10:59 PM
canehdian_guy
Oct 5, 2015 03:01 PM
maru_two
Jun 4, 2012 01:44 AM
IQOUTLAW
Mar 31, 2009 05:53 AM
denny
Jul 7, 2008 02:42 PM
