KAF400 crank case cover re-installation
Old Nov 29, 2024 | 10:58 PM
RaimundEge's Avatar
Default Mule 610 crankcase noise
After replacing the crankcase cover gasket and reassembly, there is a loud "klacking" sound when the engine turns.
I already checked that the balancer shaft is lined up correctly.
What else could be wrong ?
Any help is appreciated.
Old Jan 20, 2025 | 04:32 PM
RaimundEge's Avatar
Update on the klack-noise issue: it is gone
The balancer shaft hit the piston rod once a turn which caused the noise. Otherwise the engine ran fine.
After consulting the service manual I double checked the balancer shaft alignment: the dots lined up as required.
So I experimented with offsets. Here is a picture of the current setting:
crankshaft vs. balancer setup
Engine starts and runs fine with now extra noise.
Can I just assume that I have a mislabeled part, or am I doing something bad ?
Any insight/help is appreciated
sirjr
Jun 10, 2011 06:43 PM
rescuepanther
Mar 19, 2007 01:56 AM
alohasb7
Mar 15, 2007 08:56 AM
FiveOMaster
Aug 29, 2006 08:04 PM
KAWABUNGA
Feb 19, 2006 04:06 AM
