wont start
Old Mar 20, 2006 | 04:40 AM
kawibanshee's Avatar
Default wont start
i got a 500r motor and trans i got it on my banshee ok the problem the starter kick over but wont start the motor it just spins any sugestions[sm=bounceybounce.gif]
Old Mar 20, 2006 | 08:20 AM
txredneckmedic's Avatar
Default RE: wont start
got spark?
Old Mar 20, 2006 | 08:25 AM
lemac's Avatar
check for fuel, spark, and compression. with these three you should atleast get it to stumble or start.
Old Mar 20, 2006 | 04:06 PM
i got sparkand good fuel i might need to drain the bowl and clean them out also the big starter gear is it supose to be welded to the bowl and magnet thing the thingis that i turned a corner and it cut off on me then it wouldnt start back up then after that it made that free spin noise
Old Mar 20, 2006 | 04:43 PM
lemac's Avatar
hummmm.... so its carb. or fi
Old Mar 20, 2006 | 06:46 PM
its carb
Old Mar 21, 2006 | 01:31 AM
ok i took it apart and i got spark and fuel i cleaned the carbs now it all back fires out of the carbs is there a certain way the starter stuff goes for the timing
Old Mar 21, 2006 | 05:43 AM
lemac's Avatar
ok so its spittin out the carbs? I never worked on bikes b4, but sounds like the timing is off
Old Mar 22, 2006 | 05:39 AM
k i found out what was wrong the flywheel keeper broke so i got a new one does any body know how to time the ex500 motor
IQOUTLAW
Mar 23, 2010 02:33 PM
henryhoehandle
Sep 20, 2006 11:21 PM
05ninjazx6r
Mar 29, 2006 11:47 PM
DJNYC
Sep 21, 2005 04:00 AM
