Strong Argumant for Synthetic-Follow link
Old Jun 23, 2007 | 02:05 AM
gerrynolan's Avatar
Default Strong Argumant for Synthetic-Follow link
Here is a link to some cool information about Synthetic oil. I know for sure I'll use it once My "easy Break in " is done.
http://www.autoeducation.com/autosho...l-change-1.htm
Old Jun 23, 2007 | 03:26 AM
Default RE: Strong Argumant for Synthetic-Follow link
wow, a long read.
Old Aug 4, 2007 | 02:50 PM
RonInFla's Avatar
[:@]Unfortunately the problem is the filter... the cheap paper element inside the canister only has a 4000 mile lifespan...next thing you know, the guts deteriorate, all the little particles and crap hit the oil pump in 1 blast and spreads thru the whole motor in a matter of seconds. Oops!!!
NOW: everything goes wrong at once, and yoursctatching your head wondering if it was the synthetic oil?No, it's the non-synthetic filter element failing, from neglect.
In the owners manual in new bikes ('06 and up) the maintainence schedule is saying filter every 4k and oil every 8k. which is fine. The oil companies are doing great things with convential oils to make them last longer.
Old Aug 4, 2007 | 02:58 PM
Notstock's Avatar
ORIGINAL: RonInFla
Think you have it backwards there bud, oil every 4 and filter every 8.
I guess you could do the filter without the oil,suspend the bike fronthefront wheel then you can get the filter out without losing all the oil
Old Aug 4, 2007 | 06:14 PM
gerrynolan's Avatar
I know people with 1/2 million miles on cars doing 25k synthetic oil changes. The trick is to change the filters a few times inbetween oil changes. My KLX only takes 1.5 US Quarts so every 2500 miles or so I'll just do a full Synthetic oil & filter change. I've heard that when they start to shift a little rough, It's time to change the oil. Don't be penny wise and dollar foolish
Old Aug 4, 2007 | 06:46 PM
RonInFla's Avatar
oil level on sport bike is "lower" than filter. you can change it and only loose what's in the filter.
Old Aug 4, 2007 | 06:47 PM
Kohburn's Avatar
or you could just change full synthetic and filter both every 5k which is what i do (on cars)
i'm still not convinced full synthetic isn't harmful to the clutches in sportbikes because i've found arguments for both sides.
Old Aug 4, 2007 | 10:36 PM
ORIGINAL: RonInFla
So true. I still like draining through a filter(coffee filter lets say)into aclean container, change the oil filter, replace the oil. Add if needed.
edit: clarification
Old Aug 4, 2007 | 11:15 PM
Notstock's Avatar
Filter above the oil level or not, my manual says and I thank all three of them say 4k for oil and 8k for the filter.
I guess this wouyld be for regular oil and not syn. I use syn in my bikes and replace oil and filter every 5k!
Old Aug 4, 2007 | 11:28 PM
Which manual is that NS? change every..(km) I see that you do not follow the manual as well.
Nobrakes
Jan 13, 2009 04:02 AM
redfieldrocket
Jun 24, 2008 05:12 PM
shinobi636
Sep 5, 2007 05:03 PM
Marty
Oct 25, 2006 05:22 AM
johntammi
Ninja 500R
Jul 12, 2006 02:45 PM
