oil question
Old Jun 10, 2009 | 02:03 AM
ericr1113's Avatar
Default oil question
CAN ANYONE HELP? I THINK MY BIKE IS LOW ON OIL BUT NOT SURE. WHERE SHOULD THE OIL BE AT IN THE SIGHT GLASS. I CAN SEE IT WHEN ITS STRAIGHT BUT NOT WHEN IT IS PARKED. i AM STILL WAITING ON THE MANUAL TO ARRIVE.
Old Jun 10, 2009 | 02:15 AM
Odimus's Avatar
caps off you're hurtin' my ears!!! you should be able to see it when the bike is straight up...is this the 250???
Old Jun 10, 2009 | 02:24 AM
put the ride on the center stand if it has one, or keep the ride level (straight up as mentioned). 1/2 up the sight glass for the oil level.
Old Jun 10, 2009 | 01:18 PM
yup what he said
Old Jun 10, 2009 | 04:08 PM
jeffzx9's Avatar
I think I posted this a day or two ago: If you have to ask, then change your oil and filter! Replace with the correct amount of oil (not 4 quarts if it says 3.75) and look at your sight glass on level ground. Yes; probably the exact same outcome of what Drag recommended above^, but eric, there is nothing like direct experience to make the information stick.
Old Jun 10, 2009 | 11:56 PM
Worlok14's Avatar
When you look at the site glass, if you see little gremlins peering out at you, drain your oil immediately
fixin737s
800, 800 Classic & 800 Drifter
Jun 10, 2008 07:59 PM
Icantrideabike
Sep 22, 2006 02:58 AM
slablocal
Jul 8, 2006 08:21 AM
kawi636
Apr 4, 2006 09:26 PM
