Ninja 300 only starts in neutral
Old May 3, 2018 | 03:27 PM
Cantaloupe's Avatar
Default Ninja 300 only starts in neutral
Hey guys, so I was installing some aftermarket levers yesterday, and after I put them on, the bike would only start in neutral. Moreover, when I tried to intentionally stall out the bike, it would not, it would keep going. I put the oem levers back on and still the same problem. The little clutch cable/switch is plugged in, and the side stand is down.
I did tug on the cable a lot when installing, before I figured out turning the adjuster would give more room to work with. Any advice before I take it to the shop? Thanks.
Old May 3, 2018 | 03:59 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki Streetbikes/Sportbikes - Kawasaki Motorcycle Forums
FrankCastle
KLX125 & KLX125L
Apr 10, 2016 06:24 PM
Kor
Aug 11, 2013 09:13 PM
kyrral
Jan 31, 2011 12:33 AM
bwake 5
Nov 15, 2007 03:34 AM
Kibara
Sep 21, 2007 02:29 AM
