09 KLX 351 starts, stops, starts, stops, help
I had 20 city miles on a new 351. After about 4 miles on the highway at 65 the bike just quit. Came to a stop and was able to restart. Same thing 2 miles later. 3rd time wouldn't. After overnight on my trailer started right up on choke. Idled for one minute, quit, and wont restart. Any clues?
You need to find out what is missing. Spark or gas.
Fire it up, run it till it quits and give it a squirt of gasoline directly in the carb See if it will start on that.
Next (or first) Pull the spark plug, inspect it, hook it up to the wire, make sure the spark plug is grounded and crank the engine. See if you have spark.
Motor oil full? Full gas tank? All lines and hoses hooked up? Radiator full?
Good luck.
Its 9*f here with lots of snow. I aint going no where on the bike.
Good luck.
Well if you were doin 65 when it stalled, at least that rules out your idle circuit in the carb.
As David said, check your spark. Sounds like you may have a loose connection issue. IIRC you just had your motor apart for the 351 kit, that could bring on other issues related to timing if the teeth weren't set properly.
Either loose electrical connection, or, my first guess would be something as simple as a crimped/occluded carb vent line or a gas tank vent line not on correct. If it were timing-related, it would show up immediately, not run for a while then quit, then run, then quit.
Oh, yeah! Does your bike still have that little screen filter that goes in the fitting on the petcock where the fuel line enters?
did you have the carb apart when you did the big bore kit to rejet?
FLoat stuck?
did you take the fuel line off the catb and open the petcock to see if fuel is flowing to the carb? Pinched vent line. If no fuel flows or trickles out, open the gas tank cap and see if there is better flow.
FLoat stuck?
Dan
