Ninja 300 only starts in neutral
Hey guys, so I was installing some aftermarket levers yesterday, and after I put them on, the bike would only start in neutral. Moreover, when I tried to intentionally stall out the bike, it would not, it would keep going. I put the oem levers back on and still the same problem. The little clutch cable/switch is plugged in, and the side stand is down.
I did tug on the cable a lot when installing, before I figured out turning the adjuster would give more room to work with. Any advice before I take it to the shop? Thanks.
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki Streetbikes/Sportbikes - Kawasaki Motorcycle Forums
