Fixing fairings
Old Feb 4, 2011 | 10:01 PM
08zxrid3r's Avatar
Default Fixing fairings
I just got some spare fairings and they have some holes in them. What are the cheapest and easiest ways to fix them?
Old Feb 5, 2011 | 02:14 AM
Welcome to KF 08zxrid3r
I have had good luck melting abs shavings into an MEK solution in a good lab squirt container. Apply the liquid/melted solution in a prepped fairing. Works pretty good.
Old Feb 5, 2011 | 03:31 AM
gammac's Avatar
Yes. There's a product called "Plastex" which comes in small packages that does the above. Costs about $25.
gammac
Old Feb 5, 2011 | 02:35 PM
jeffzx9's Avatar
(I thought they made "cross your heart" bras?)
HA!
Old Feb 9, 2011 | 02:27 AM
08zxrid3r's Avatar
Sweet, do i need to put any sort of backing if the holes are bigger?
Old Feb 10, 2011 | 12:11 PM
gammac's Avatar
www.rideout plastics.com has data sheets on industrial adhesives. "Weldon" is the name. I only had to repair cracks and the stuff I got was applied to the crack (spread apart) , brushed on with an artists paint brush allow to spring back together held it for a couple of minutes and didn't use the bike for a day or so. Drys pretty quick. I went to a plastic sign maker in Brisbane and he sold me the stuff. Backing would be necessary if you have an actual hole in the fairing and you need to know what the fairings are made of so you can obtain filler material.
gammac
85vulcan
Jan 28, 2011 02:29 PM
yusafk
Dec 6, 2010 10:36 PM
adramalech
May 19, 2010 04:22 AM
KLXelent
May 11, 2009 03:47 AM
Mott Power
Ninja 250R
May 26, 2007 05:43 PM
