Z750 LTD Rebuild
Hmmm either we don't have this T canister or I just can't draw up the picture in my head. The only things I know that are connected to the carbs would be the prime fuel line to carb 3 or 2, the throttle cable, the black main fuel line to that swivel thing that runs through all of the carbs. There are two like crankcase vent / egr things on the exhaust side of the valve cover but they are connected together with a 8 inch hose.
Excuse my terminology
Off topic, but I was working on one of my buds' 2001
z7s today, it had the cannister that I was trying to mention. Yes, it is a smog item but if yours were to be removed and the vacuum lines were to be re-routed....that would cause vacuum issues if not done properly. Did you replace the broken black box yet?
Possible problem areas that I feel are causing this.
Since the wires and plugs are good and getting spark, maybe the spark isn't heavy enough soo....
Coils.
Rectifier / Regulator.
Points Assembly.
I'm going to measure the coils soon. They're been sitting 15 years, along with everything else so I'm HOPING i can get a definitive diagnostic conclusion from their resistance. I'm reading a lot that their readings will often be inconclusive.
Blah.... If this were a crx, it would've been fixed by nao =p
Coils.
Points Assembly.
Tomorrow? Get in there today lol. Check out that wiring diagram and find out if any of those ignitor wires from the points are pinched on the case or shorting to the frame =p
http://kz.bike-night.com/media/KZ750-E2.jpg
Ignition Kit - Kawasaki KZ750 KZ650 KZ550 Equivalent to OEM: 21008-027 21008-028 21013-037 from Z1 Enterprises, Inc.
Tune Up Contact Points Condenser Kawasaki KZ750G1 LTD | eBay
1981 KZ750 LTD 4cylinder Ignition Problem
KZ750 LTD H2 1981 IGNITON COIL TESTING
ThatRat
Jun 2, 2012 10:54 AM
