Z750 LTD Rebuild
Old May 3, 2012 | 02:43 PM
sanfranciscotreat's Avatar
Default Z750 LTD Rebuild
Hello all. I'm New here and I'm taking on the task of rebuilding / cleaning an 81 z750 LTD motor. It's going to be taken off the bike and maintained and then put back on the bike. Problems were...
Loss of power
Slow rev
Rough start
Rough idle
Cold air out right ride exhaust
Bad plug
Dirty carbs
Dirty gummed manifold
Low compression.
Now is there a checklist way To go about doing this?
Just want to hear some thoughts ideas.
Old May 3, 2012 | 03:01 PM
welcome to KF, good luck with the build!
Old May 3, 2012 | 04:12 PM
I'm hoping to get some information from someone who has worked on one of these engines as I have almost no motorcycle experience but I am mechanically inclined and have built and worked on several I-4 Honda engines
Old May 3, 2012 | 07:43 PM
jeffzx9's Avatar
SanFran, give us a bit more history on the bike if you have any. Since it is at least running (but poorly) I would begin with general fundamentals, then progress to specific remaining problem areas. For example, clean gunk from all affected areas, fresh plugs, filters, fluids, check tolerances, torques, compression, inspect/replace usual wear parts (carb boots, seals, gaskets, etc.), look for odd wear points and why, any restrictions (mouse nest in the header pipes...), then fire it up and refine any remaining problem areas.
Welcome to KF. Keep us posted!
Old May 4, 2012 | 01:49 AM
Welcome to KF
How many miles on this engine? Age is a killer to the rubber parts as mentioned. What were your compression test readings?
I am lazy, so generally the engine stays in place for general checks and adjustments.
Old May 4, 2012 | 03:09 AM
Welcome to KF
Thanks guys for the response. This is going to be a big project or me.
It's been sitting probably 10 years. Head gasket blown so no at least 2 dead cylinders. Remaining 2 probably only get about 80-100 psi each.
Old May 4, 2012 | 01:09 PM
Would a top end gasket set for a KZ750 work for a KZ750 LTD?
Also, what's the difference betwix the two? =p
Old May 4, 2012 | 04:21 PM
Since you are talking about the 4 cyl engine KZ and not of the KZ twin, then I would think that the head gasket would fit. (spendy buggers it seems as well for oem)
I am not a historian nor a mechanic, but I think that the main differences were the drive setup. The LTD being belt driven, the KZ being chain driven, the spectre being shaft driven. And of course kawi had the twin cyl and the 4 cyl versions. (must have been under new management or something. lol)
Old May 4, 2012 | 04:43 PM
Hey dragone that's awesome news. Thanks! The LTD that I'm going to be working on is chain drive. Can't get the damn chain off primary sprocket to remove motor. Is terr a master link? Looking through the specs, it looks like if I remove or loosen anything from primary shaft, I'll be opening up a can of worms :x.
Old May 4, 2012 | 07:21 PM
If it is a continuous chain, either break the chain or pull the swing arm as in all rides.
edit: This has been my buddy, any grinding wheels and tools are optional.
