Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
BIG BORE KITS
Old Apr 22, 2007 | 09:51 AM
2006636r's Avatar
Default BIG BORE KITS
if anyone knows of any company thats makes big bore kits for 2006 636 that would be great if u could let me know because i have been searching for a while thanks.
Old Apr 23, 2007 | 08:55 AM
speedracer138's Avatar
Default RE: BIG BORE KITS
Search the posts in the ZX6R forums. There are 2 companies that make Big Bore kits for the 636's. Wiseco is one and there is another. It will make it to 662cc's but you will have to re-plate the cylinders. http://www.dynoman.net/engine/pistons/kawa.html
I think JE makes piston kits also for the 636.
Here's another 655cc kit:
http://www.procycle.us/bigbore/bbstreet_kaw.htm
Old Apr 23, 2007 | 01:56 PM
06zx6r's Avatar
will the 03-04 be the same for the 05-06 motor. i thought that they were two diffrent motors
Old May 2, 2007 | 11:40 PM
I think the pistons are the same but the cylinders are slightly different due to the windows the cut between the cylinders to reduce windage losses. The heads are different and so is the bottom end.
Old May 10, 2007 | 06:56 PM
06zx6r's Avatar
so they cant be used then. why do they only sell them for the 03-04 and not the 05-06
Old May 13, 2007 | 05:56 AM
shinobi636's Avatar
Get with these guys. They will build you whatever you want. Falicon cranks I didn't see any 636 parts, but these cats are about the best around. I've built stroker Hondas, and Kawis from their parts, and still have the Honda, and it still runs without issue.
Old May 13, 2007 | 07:11 AM
ORIGINAL: 06zx6r
Call them; I'm pretty sure you can put an 05-06 topend on an 03-04. HoweverThe 05-06 heads have Oval intake ports and you will have to get those TB's & harness and all.
mattyw
Oct 2, 2009 02:02 PM
punkenduro09
May 6, 2009 07:53 PM
bobm417
Aug 18, 2007 12:14 PM
maniac
May 26, 2007 12:36 PM
mattallica
Ninja ZX-7R
Jan 20, 2006 02:25 PM
