BIG BORE KITS
if anyone knows of any company thats makes big bore kits for 2006 636 that would be great if u could let me know because i have been searching for a while thanks.
RE: BIG BORE KITS
Search the posts in the ZX6R forums. There are 2 companies that make Big Bore kits for the 636's. Wiseco is one and there is another. It will make it to 662cc's but you will have to re-plate the cylinders. http://www.dynoman.net/engine/pistons/kawa.html
I think JE makes piston kits also for the 636. Here's another 655cc kit: http://www.procycle.us/bigbore/bbstreet_kaw.htm |
RE: BIG BORE KITS
will the 03-04 be the same for the 05-06 motor. i thought that they were two diffrent motors
RE: BIG BORE KITS
I think the pistons are the same but the cylinders are slightly different due to the windows the cut between the cylinders to reduce windage losses. The heads are different and so is the bottom end.
RE: BIG BORE KITS
so they cant be used then. why do they only sell them for the 03-04 and not the 05-06
RE: BIG BORE KITS
Get with these guys. They will build you whatever you want. Falicon cranks I didn't see any 636 parts, but these cats are about the best around. I've built stroker Hondas, and Kawis from their parts, and still have the Honda, and it still runs without issue.
RE: BIG BORE KITS
ORIGINAL: 06zx6r so they cant be used then. why do they only sell them for the 03-04 and not the 05-06 |
