2000 ZX9R TICKING SOUND AT IDLE???
Old 04-28-2008, 05:49 PM
Whouok's Avatar
Default 2000 ZX9R TICKING SOUND AT IDLE???
PLEASE LET ME KNOW IF WITH 19000 MILES I SHOULD HAVE IT RE SHIMMED? IS THAT WHAT IS THAT WHAT THE TICK IS????
Old 04-29-2008, 01:37 AM
dieselmech's Avatar
Default RE: 2000 ZX9R TICKING SOUND AT IDLE???
I notice that my engine ticks a little when its do for an oil change, could be the valve also could be the timing chain, are you still running the factory adjuster or have you switched to an APE manual adjuster? The factory could possibly be at its max adjustment and not keeping enough tension on the chain, the APE might simply need readjusted.
Old 05-02-2008, 08:59 AM
Ninja500r's Avatar
I too noticed the same sound. Honestly though mine is only at idle after a cold startup. I pin pointed the area to be near my clutch. I know open clutches make a noticably loud tick. Just a suggestion but its an easy place to start. My 98 ZX9R has under 6k so i definetly dont need a clutch but maybe you do?
Hope I helped some1!
Old 05-03-2008, 11:29 AM
xyz1000rr's Avatar
I have noticed it too after winter start up on my 2000 zx9r was a little worried myself i got my valves shimmed last fall at 12000-mi cuz the manual said to but the mecanic said it didnt really need it wish i knew what was causing it
Old 05-03-2008, 10:58 PM
Interesting statement The mechanic checked the specs and they all were within spec I assume? And no "shimming"/adjustments were needed?
10w-40 oil is recommended.
pg 5-12 engine top end for the CCT
see also oil pressure relief valve check pg 7-9
Also look on page 17-4 in your 9r manual which may assist with the clutch noise possibility
Old 05-09-2008, 05:44 PM
xyz1000rr's Avatar
Yea he said they were all good but he made sure anyway cuz i told him to he said you usually wont really need it till closer to 20,000 mi. i do have a complaint about the service though i had him change all the fluids and my radiator catch bottle looks worse than before. he didnt clean the window in the bottlewhen he did it which i wish he woulda but i understand but now it does look dirtier than before mabe i will do it again myself its leaving a crusty looking film over the catch bottle window
nmcurley
04-15-2009 09:53 PM
Whouok
Ninja ZX-9R
04-29-2008 08:59 AM
double d6
12-10-2006 12:24 AM
BladeZX6R
03-28-2006 04:53 AM
susanscatdog
01-07-2006 08:20 AM
Quick Reply: 2000 ZX9R TICKING SOUND AT IDLE???
