2000 zx9r hesitation
Old Jan 12, 2007 | 05:05 AM
xyz1000rr's Avatar
Default 2000 zx9r hesitation
got a 2000 zx9r that seems 2 have just the slightest hesitation between twisting the grip and accelerating especialy steady speed to hard acceleration. Not much just enough to notice not as crisp as the same year zx6r i used to have is this normal for this bike or is something wrong? thanks 4 any info
Old Jan 12, 2007 | 08:43 AM
Default RE: 2000 zx9r hesitation
Welcome to KF
Although I am not too familiar with your new ride or the 6r that you mentioned.
If you turn the choke up just a bit, will that make a diff in finding out your question/answer?
Old Jan 14, 2007 | 12:41 AM
xyz1000rr's Avatar
thanks for the welcome. not sure if might be a jetting problem, the bike has a nice D&D full system pipe but not sure(bought it that way) if it has a jet kit. It happens when i goose it or if i dip the clutch to raise revs and let it out fast just kinda bogs 4 1/2 a second then accelerates strong mabe i just got spoiled on my old Vfr with feul injection. this 1's more fun though. to cold to try the choke thing expecting snow 2morrow
Old Jan 14, 2007 | 01:14 AM
If you suspect a jetting prob, do a plug chop. The choke idea was to richen things which are more noticeable from idle and mid. Works well for wet riding. I wouldalso thinka .5mm shim under your needles with the choke back to normal would be a good try.
jonesy0130
800, 800 Classic & 800 Drifter
Dec 9, 2007 11:14 PM
acgill
Jul 10, 2007 09:38 PM
eastcoast
Jun 7, 2007 05:16 AM
bgillette78
Apr 15, 2007 09:04 AM
mgspencer
Feb 20, 2007 06:08 PM
