Hesitation
I started the ol' bike up yesterday and took it down the street just to let it run for a while. When I got it up to about 4-5 grand in firstit would kind of miss a little and then continue running fine. I took it back to the garage and put her into neutral and reved it and no miss....so I took it back down the road and it did it a couple times....and then finally quit....I dont know if it was because it was cold out or cuz it sat a couple weeks....maybe carbs dirty plugs bad....only has 6500 on it....any insight would be great thanks
Should just be a screw on the bottom of each bowl you will need to loosen. Buy a foot or two of small rubber line so you can connect it to each nipple of the four bowls. That way you can direct the old gas into a container.
