Hesitation
Old 04-14-2007, 03:37 AM
bgillette78's Avatar
Default Hesitation
I started the ol' bike up yesterday and took it down the street just to let it run for a while. When I got it up to about 4-5 grand in firstit would kind of miss a little and then continue running fine. I took it back to the garage and put her into neutral and reved it and no miss....so I took it back down the road and it did it a couple times....and then finally quit....I dont know if it was because it was cold out or cuz it sat a couple weeks....maybe carbs dirty plugs bad....only has 6500 on it....any insight would be great thanks
Old 04-14-2007, 04:07 AM
Default RE: Hesitation
Glad it cleaned up. Generally water in the bowls in cold weather tend to form ice and can cause issues for a spell.
Old 04-14-2007, 07:20 AM
so can I put a water remover through the system to help prevent that or does it just work itself out
Old 04-14-2007, 07:56 AM
why? just drain the bowls to see if everything is good.
Old 04-14-2007, 09:54 AM
markmeinteil's Avatar
1+
Start with the easy stuff first.
Old 04-15-2007, 12:50 AM
ok then just drain the bowls huh
Old 04-15-2007, 01:19 AM
Should just be a screw on the bottom of each bowl you will need to loosen. Buy a foot or two of small rubber line so you can connect it to each nipple of the four bowls. That way you can direct the old gas into a container.
Old 04-15-2007, 08:16 AM
dang, wish my 7 was that easy to do. Had to place a pan under the carbs when I removed the screw.
Old 04-15-2007, 09:03 AM
Didn't your carbs have the drain/vent nipples?
Old 04-15-2007, 09:04 AM
hahaha! I said nipples!
jonesy0130
800, 800 Classic & 800 Drifter
12-09-2007 11:14 PM
acgill
07-10-2007 09:38 PM
eastcoast
06-07-2007 05:16 AM
mgspencer
02-20-2007 06:08 PM
xyz1000rr
Ninja ZX-9R
01-14-2007 01:14 AM
Quick Reply: Hesitation
