TURN SIGNAL PROBLEM
Old Jun 17, 2008 | 02:42 PM
preemo_21's Avatar
Default TURN SIGNAL PROBLEM
i have purchased some license plate turn signals on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...065695421&rd=1
..but i installed them and when i turn them on, they stay on...they don't blink.
i had the front signals on too and tried to switch wires but no progress. does anyone have any ideas?
Old Jun 18, 2008 | 02:54 AM
stone_sour09's Avatar
Default RE: TURN SIGNAL PROBLEM
not sure, i was gonna say maybe the wrong wires are hooked up,but you already checked that, so....not sure.
Old Jun 18, 2008 | 03:38 AM
ford35's Avatar
your new bulbs don't have the amps/watts to run the flasher... two things you can try is....1: buy an electronic flasher or ..2:get load equlizer
Old Jun 18, 2008 | 05:21 AM
preemo_21's Avatar
where can i purchase these things ?
Old Jun 18, 2008 | 08:39 PM
ford35's Avatar
the flasher or the load equlizer is at autozone... bring in your flasher they will need to match it to the type you are using..
you can only use 1 type not both ... you are better of with the electronic flasher as it not hard to install
the load equlizer is in the same area as flasher near the led bulbs
the flasher maybe a prob with the 93 as the type you may need to find an aftermarket led flasher relay on the net for 93 zx7
..... i work there
Old Jul 18, 2008 | 03:25 AM
cory_cnx's Avatar
guys i have the same problem but only the left side doesnt blink i thought that it was the bulb but it wasnt thanks
Old Jul 18, 2008 | 05:59 AM
preemo_21's Avatar
i was told to get an electronic flasher from autozone, so i went to autozone to get one. installed it, and it works just fine. just get an electric flasher (i believe mine was called blazer, it's a clear yellow flasher) for a couple dollars and try it, it may work for ya.
Old Jul 26, 2008 | 02:48 AM
dest101auk's Avatar
hey preemo, i kinda sort of have the same problem except my turn signals won't work at all now. where exactly do I install the electric flasher? Sorry I know it sounds dumb. Thanks
Old Jul 26, 2008 | 03:27 AM
preemo_21's Avatar
it's behind the left rear fairing. it looks like this:
http://cgi.ebay.com/ebaymotors/Kawas...spagenameZWD1V
the electronic flasher at autozone is called blazer, it's yellow.
Old Jul 29, 2008 | 06:39 PM
dest101auk's Avatar
thanks
dirt_beaver
Dec 20, 2007 12:50 AM
sfgpgt
Aug 15, 2007 11:46 PM
Hermolicious84
Jul 19, 2007 07:16 AM
YYY.GUY
Nov 2, 2006 11:12 PM
ReaperFox
Jul 11, 2006 04:10 AM
