Problem inserting Acerbis turn signal sockets
Old Nov 2, 2006 | 09:54 PM
YYY.GUY's Avatar
Default Problem inserting Acerbis turn signal sockets
I'm having trouble to fully seat the turn signal sockets on my Acerbis Dual Sport Handguards.
The sockets are all rubber and should be a press-fit into the turn signal housing. I've tried pressing hard enough that I thought it would bend the contacts or break the bulb, and they just won't fully seat properly. I don't think they were meant to only go in part way because the bulb would not be fully visible, and it seems like they would shake themselves loose. Anybody else run into this difficulty?
I was thinking of spraying some kind of lube on them, but worried that the wrong kind (e.g.: silicon spray on silicon rubber) could deteriorate the socket.
Anybody have any bright ideas for my not so bright problem?
FYI - I picked up a 15' roll of 1/4" heat shrink tubing to put over the turn signal wires for some protection (not just over the solder joint, but over the whole length of the wires). Looks like it will be a very clean installation. Pics to follow when I'm done.
Mike
Old Nov 2, 2006 | 10:47 PM
a16tony's Avatar
Default RE: Problem inserting Acerbis turn signal sockets
try a little Armorall for lube.
Old Nov 2, 2006 | 10:51 PM
dazjr's Avatar
I just used a little lube. It doesn't take much. Those plugs are about impossible to get all the way in without something. With the lube, I can push mine all the way in until the bulb makes contact with the lens. I sure hope there isn't anybody out there with a dirty mind....lube...push all the way in....[sm=gobble.gif]
Old Nov 2, 2006 | 10:56 PM
I used windex, went right in and they have not moved yet.
Old Nov 2, 2006 | 11:12 PM
YYY.GUY's Avatar
Thanks for the tips ... they're all good!
a16tony: Excellent idea!
deej: I saw "My Big Fat Greek Wedding" ... wonder why I didn't think of that?!??
dazjr: I confess - I was a little concerned about how to word a post about "lube". But don't get any wrong ideas about me thanking you for the "tip"!!!
Mike
Trevi
May 26, 2009 11:08 AM
dirt_beaver
Dec 20, 2007 12:50 AM
sfgpgt
Aug 15, 2007 11:46 PM
Hermolicious84
Jul 19, 2007 07:16 AM
ReaperFox
Jul 11, 2006 04:10 AM
