TURN SIGNAL PROBLEM
i have purchased some license plate turn signals on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...065695421&rd=1 ..but i installed them and when i turn them on, they stay on...they don't blink. i had the front signals on too and tried to switch wires but no progress. does anyone have any ideas? |
RE: TURN SIGNAL PROBLEM
not sure, i was gonna say maybe the wrong wires are hooked up,but you already checked that, so....not sure.
your new bulbs don't have the amps/watts to run the flasher... two things you can try is....1: buy an electronic flasher or ..2:get load equlizer
where can i purchase these things ?
the flasher or the load equlizer is at autozone... bring in your flasher they will need to match it to the type you are using..
you can only use 1 type not both ... you are better of with the electronic flasher as it not hard to install the load equlizer is in the same area as flasher near the led bulbs the flasher maybe a prob with the 93 as the type you may need to find an aftermarket led flasher relay on the net for 93 zx7 ..... i work there |
guys i have the same problem but only the left side doesnt blink i thought that it was the bulb but it wasnt thanks |
i was told to get an electronic flasher from autozone, so i went to autozone to get one. installed it, and it works just fine. just get an electric flasher (i believe mine was called blazer, it's a clear yellow flasher) for a couple dollars and try it, it may work for ya.
hey preemo, i kinda sort of have the same problem except my turn signals won't work at all now. where exactly do I install the electric flasher? Sorry I know it sounds dumb. Thanks
it's behind the left rear fairing. it looks like this:
http://cgi.ebay.com/ebaymotors/Kawas...spagenameZWD1V the electronic flasher at autozone is called blazer, it's yellow. |
thanks
