THROTTLE RESPONSE
Old Jul 7, 2008 | 04:40 AM
preemo_21's Avatar
Default THROTTLE RESPONSE
I'm in 6th going about 110 then slowed down...dropped the gears and when i'm at the speed limit, i wasn't getting any gas from the throttle. so i pulled over for about 10-15 minutes..it started up and i'm getting gas from the throttle again. seems like it only does that when i'm riding hard. a friend told me it could be my fuel filter. any other ideas (alternator, starter)?
Old Jul 8, 2008 | 03:17 AM
Default RE: THROTTLE RESPONSE
Check your screens and filters since that is easy to do. Then move on to your fuel pump if needed. It is easy enough to check your fuel pump operation withgauge. Your manual will help you out on this test as well.
Old Jul 9, 2008 | 05:16 AM
Prom's Avatar
If your filter is old it is possible it draw more fuel than the filter can handle and dry out the bowls, Without further information, I cant think of anything else to help you. Let us know how it works.
Juliet
Aug 2, 2010 01:57 AM
horizonod
Dec 19, 2008 06:53 AM
KevinInColorado
Aug 2, 2008 08:19 PM
longinforabike:D
Ninja 500R
Oct 7, 2006 01:22 PM
ZX_9r
Ninja ZX-9R
Jun 24, 2006 05:02 PM
