klx 250s no throttle response
Old Aug 2, 2008 | 12:09 PM
KevinInColorado's Avatar
Default klx 250s no throttle response
klx 250s rejetted for high altutude idles only. If the trhottle is cracked at all it dies. any help??
Old Aug 2, 2008 | 12:27 PM
neilaction's Avatar
Sounds like the main jet is too small.
That was what was happening when I first put on the pumper.
Swapped the stock 127 main to a 142.5 and it ran fine.
But I'm no expert.
Everything I know I learnt from people on this site.
Old Aug 2, 2008 | 12:54 PM
maybe the diaphram isnt in correct... or the needle isnt seated right....
Old Aug 2, 2008 | 03:12 PM
WestOzKLX's Avatar
We'll need more info' on the jetting and other mods to give some feedback.
How about that!
Old Aug 2, 2008 | 04:31 PM
stock jet 118 put on 112 at 10,000 feet elevation
Old Aug 2, 2008 | 05:07 PM
WestOzKLX's Avatar
I'd try #125 Main and stick with the #35 pilot.
I read of guys using this up to 9000 feet.
The #115 Main is way too lean. The #118 is lean from stock.
In AUS we get a #132 main as stock. Runs real good out of the crate.
Old Aug 2, 2008 | 08:19 PM
ZX1100F1's Avatar
Kevin,
After just adding a KDX snorkel and UNI air filter I had to rejet my bike with a 122 main and then the bike ran perfectly all the way from 4,600ft to over 10,00ft, the diaphram may also not be seated properly as well (as mentioned above) but is you changed to a 112 jet the engine will never run right.
Duane Lobbestael
Apr 14, 2011 11:02 PM
horizonod
Dec 19, 2008 06:53 AM
preemo_21
Ninja ZX-7R
Jul 9, 2008 05:16 AM
longinforabike:D
Ninja 500R
Oct 7, 2006 01:22 PM
ZX_9r
Ninja ZX-9R
Jun 24, 2006 05:02 PM
