My Spare Parts Project
Old Dec 30, 2013 | 06:05 PM
2fat2fly's Avatar
I got a delivery from UPS that made me happy.
And it was just like Christmas:
I got Tubing! Thank you Santa!
It's for these little projects:
I'll be doing some drilling and fitting & then some welding will get done later this week. The one at the bottom right is what the other four will look like.
Old Dec 30, 2013 | 06:06 PM
2fat2fly's Avatar
Here's a couple things I've had made:
They all have the original part laying next to them.
Fuel tank mounts:
You've all seen this before:
It's the petcock mount.
And one of the rearsets that came with my superbike parts stash. I made a new one simply because I don't want to destroy the original if I wreck this bike, so the original is getting put back in it's box and put on a shelf.
I'm still working on other parts for this project. These are just some things my brother whipped up on his Bridgeport.
Old Dec 30, 2013 | 06:07 PM
2fat2fly's Avatar
The Christmas holiday really didn't go as I had planned. My wife had agreed to leave me alone for the first part of last week so I could spend a couple days in the garage. Needless to say that didn't happen. :eye:
I did manage to get a couple things done though. I stripped the subframe to do the bare metal finish on the whole thing and when I got all the paint off I discovered a fair amount of corrosion. Here's the pictures of that:
Old Dec 30, 2013 | 06:08 PM
2fat2fly's Avatar
So I had to back up a little. I bead blasted the subframe to remove the corrosion and started over on the finish. The good news was that the corrosion wasn't too bad to save the part. All that corrosion is only on the surface so it was an easy fix. I also received some of my titanium bolts.
Christmas for the fat kid::banana:
I also fabricated a crankcase vent tank for the bike ( this was done when I was helping CCM out with a part or two):
Old Dec 30, 2013 | 06:09 PM
2fat2fly's Avatar
I also have the other rearset in work:
Old Dec 30, 2013 | 06:10 PM
2fat2fly's Avatar
I did get the subframe to a finish I was happy with. I clear coated it and the brackets in the pictures for corrosion protection.
I'll be using ti. bolts to put it all together.
Old Jan 9, 2014 | 07:03 PM
2fat2fly's Avatar
It's been a while since my last post, so let me update a little:
I have the other rearset in work:
almost finished:
These are spacers for the front fender that I made out of aluminum to replace the steel originals:
[URL=http://s180.photobucket.com/user/2fat2fly_photos/media/M%20Model%20Project/DSCN1200_zps18f5a431.jpg.html]Name:  DSCN1200_zps18f5a431.jpg
Old Jan 10, 2014 | 01:05 AM
  #28
that is alot of material to take off. wow
Were you going to satin finish your machined pieces to match the frame? or are you going to leave the machine marks?
Nice progress
Old Jan 14, 2014 | 10:14 PM
  #29
2fat2fly's Avatar
Nice progress
Thanks.
I had to use a thicker piece because the rearset has multiple contours to it and it's over 5/8" wide when you measure it overall. That piece was the thinnest piece I had that was thick enough to work.
Old Jan 14, 2014 | 10:16 PM
  #30
2fat2fly's Avatar
Last week I was out of town for work so I didn't get much done.
While I was away my brother managed to weld my fuel tank back together for me.
That makes one less thing left to do.
