98zx7 wont run
Old May 19, 2007 | 09:58 PM
vipersrt1's Avatar
Default 98zx7 wont run
ok update. now no run at all,!!!!!!!!!!!
1/2 plugs still look new and smell of gas
3/4 plugs are oil fouled..
all bowls have fuel,, pump is working,, fresh gas, fresh battery,, this is getting very tiresome,,
someone please help
oh yah spark across the board
Old May 19, 2007 | 11:54 PM
Default RE: 98zx7 wont run
what is a 1/2 and 3/4 plug?
What was the float height?
Old May 20, 2007 | 12:51 AM
vipersrt1's Avatar
geez so so sorry #1 plug #2 plug,,,,, #3plug #4plug, float height is still stock,, bike 100%stock
Old May 20, 2007 | 12:57 AM
Bluebeast's Avatar
have you tried to sync your carb's? maybe that might help if you took the carbs apart to work on them. it's just and idea maybe it will help
Old May 20, 2007 | 02:49 AM
vipersrt1's Avatar
ok further update.. just cleaned the carbs again.. the bike is completely stock no mods.. still nuthin
Old May 20, 2007 | 04:18 AM
ok, lets play basics with me. You mentioned cleaning the carbs. So you cleaned the low circuit and the high circuit. You actually measured the float heights. ok, so now what is the symptoms?
Old May 21, 2007 | 12:35 AM
vipersrt1's Avatar
ok repulled plugs, all are dry now with a little gas smell.. no more oil soak on the #3 and #4 plugs,,
cleaned all parts upper and lower to carbs, bought new battery.. it actually started for 5seconds then stalled, almost got excited.. now it just spins over.. doesnt even wanna chug or act like it is sparking, rechecked spark, its bright blue across the board,,,, opended bowls and all have fuel...
this has to be sumthing really really stupid, it only has 7600 miles on the dang thing.... but im out of ideas.. also put my thumb in all the banks, and it has compression..
Old May 21, 2007 | 02:56 AM
pozican's Avatar
ok, sounds stupid but I must ask.
It sounds like the choke wasn't engaged; Was it?
Old May 21, 2007 | 04:33 AM
I am all ears!
spara
Aug 16, 2013 01:12 AM
KNEEDEEPKZ650
Dec 13, 2007 04:01 PM
cmon6969
Oct 8, 2007 05:29 PM
tofnlows10
Aug 26, 2007 04:11 PM
mr
Ninja 500R
Apr 30, 2007 07:31 AM
