636 wont run, blows fuses..?..please help
any ideas?
earlier today i had it start twice...then would ride in 2 sec. and it would cut out...the fuse kept blowing under the seat...?
i have no idea....kinda dumb when it comes to that i guess..
RE: 636 wont run, blows fuses..?..please help
Id start by just going over the wiring harness and inspecting for anything that looks cut, pinched , broken .....etc...etc....... it may be visible ( then again maybe not )
Take your seat off, there may be a pinched wire under it and when you ride/ sit un the seat, it shorts against the frame. Does it stay running if you don't ride it? What kind of mods are done? Which fuse blows? Check your battery connections too; especially the negative. Clean & tighten it.
its the 30a fuse in little box (i wanna say its for the starter)...has + and - wires going into it..
seems to stay running when i didnt ride it, besides the last time i tried yesterday...was sitting and popped
connection are good..even got new battery to see if that would help anything..
Check the connections at the starter relay and tighten. Look for other wires pinched or shorted. Also look at your handlebar switch wires for pinced wires especiallywhere it goes between the frame & forks. Could be rubbing/ chaffing against a sharp part.
