wont run unless fully choked
Old Apr 29, 2007 | 09:06 PM
mr's Avatar
mr
Default wont run unless fully choked
i need some help here. after charging the battery fully, my 500 wont start up unless fully choked, and then as soon as i start to take the choke off, the engine dies right away. i have no idea what might be wrong. anyone have any ideas?
thanks
mr
Old Apr 29, 2007 | 09:49 PM
Default RE: wont run unless fully choked
I say pull the carbs and do a thorough cleaning especially the low speed circuit along with checking float heights and for any pin holes in the floats while you are at it.
Old Apr 29, 2007 | 09:54 PM
markmeinteil's Avatar
I don't see the battery having anything to do with it. Did you remove the battery to charge it? If so, did you remove any vacuum lines by accident? I've never seen the battery compartment of a 500 Ninja before, so I don't know what's involved when taking out the battery. Just sounds like some other item has been effected. Your battery cannot cause this problem alone.
Old Apr 30, 2007 | 06:52 AM
mr's Avatar
mr
i didnt mean that the battery had anything to do with it, i was just trying to get across the idea that i was just getting the bike out for the year.
cleaning the carbs helped a lot. it finally runs! thanks!
Old Apr 30, 2007 | 07:31 AM
Ahh... Ok. Makes more sense now.
mudbutt
May 30, 2014 07:34 PM
revhappy
Nov 20, 2008 01:45 PM
WestOzKLX
Aug 18, 2008 08:26 PM
mattkinnamon
Aug 6, 2008 03:38 PM
ntloser
Aug 26, 2006 03:13 PM
