92 zx7r runs but no RPM's
Old Jul 14, 2009 | 12:32 AM
95451's Avatar
Default 92 zx7r runs but no RPM's
Never had a problem with the bike. I started it up runs for 10mins. I get on it dies. I start it back up now it sounds like half the power and no RPMs are showing.
any ideas?
Old Jul 14, 2009 | 02:47 AM
does the ride start up again after the "no rpms show?"
welcome to kf
Old Jul 14, 2009 | 04:41 AM
95451's Avatar
yes! bike is still running. and no RPMs showing up while its running.
Old Jul 14, 2009 | 08:50 PM
95451's Avatar
Talked to a kaw tech today. he says change the plugs. would black plugs make it lose half power and make it sound like a stock bmw?
And Thank you For the Welcoming Dragone#19
Old Jul 15, 2009 | 09:14 PM
95451's Avatar
Well the anwser to my own question is yes and no. Running carb's that have been jeted. will run rich so it will turn your plugs black. But, NO! you wont lose half power.
If your plug brakes the electrode inside the Insulator mid way down. YES! you will lose half power and NO RMP's will show up while it's running. LMAO! So check all the plugs if you have this happen to you. Now I seen there was alot of views on my thread and only 1tryed to help thank you again there Dragone. So, lets try this one. What would make the electrode brake like that? The only thing I added to the bike was some LED lights. 5 total. wired them to a set of wires that had a hot and ground coming out of the wiring harness. any Ideas on this one?
Old Jul 16, 2009 | 02:45 AM
The "electrode" in the plug breaking will cause a drop in performance and will of course cause the triumph or twin sound. Thank goodness it was not the electrode producing the spark to the piston. I have not had a plug break on me though.
hmm, so what wires did you add the extra load too then?
Old Jul 16, 2009 | 04:51 AM
95451's Avatar
Not sure what the wirers were too. the colors are brown (the hot one)& blue with a red stripe (the ground)
Old Jul 16, 2009 | 10:24 PM
hmm, not sure. Good to know that you found it.
kellymj61
Jun 8, 2011 07:20 PM
rkelley548
Jun 17, 2009 07:43 PM
delthefunky
Jun 4, 2009 04:33 PM
Noahz250
Ninja 250R
May 16, 2008 10:58 PM
flyboy110b
Mar 24, 2006 07:07 PM
