tires
Old 12-22-2006, 01:34 AM
ajstockdill's Avatar
Default tires
how many miles should you go on your front tire before you change it...keep in mind i do alot of cornering to the left.
[/align]
Old 12-22-2006, 02:07 AM
shinobi636's Avatar
Default RE: tires
If the profile isn't even change the tire. Mileage doesn't matter, it's more the condition of the individual tire. If you suspect the tire is bad change it. You will subconsciously try to correct for it, and only bad things can happen.
Old 12-22-2006, 03:30 AM
MeansGo's Avatar
Default RE: tires
Amen.
Old 12-22-2006, 04:23 AM
Default RE: tires
+1 to the condition of the tire
Old 12-22-2006, 06:16 AM
speedracer138's Avatar
Default RE: tires
That and if you get close to the raised wear marks in the groove of the tires. My front wears fairly evenly even though the rearmostly wears in the center.
Old 12-22-2006, 09:42 PM
BigO's Avatar
Default RE: tires
+1 on the tire wear for me. Also the riding you do is it on the street or track?
Old 12-22-2006, 09:52 PM
KevyzToy's Avatar
Default RE: tires
Usually you can go 2 for 1. 2 rear to 1 front. But I always change in pairs. I think the bike handles better with 2 evenly worn tires.
Old 12-23-2006, 09:00 AM
shinobi636's Avatar
Default RE: tires
I do the same, and be careful on the new tires. They won't be right for the first 60-100 miles.
Old 12-23-2006, 09:17 AM
Default RE: tires
+1 to that, besides, the heat cycles on the compound for that given tire should also be the same. ie, more heat cycles on the front than the rear could cause a push in turns while the rear is fresh and is grabbing better.
Old 12-23-2006, 05:58 PM
Notstock's Avatar
Default RE: tires
ORIGINAL: ajstockdill
[/align]
Nascar for sport bikes
olderthandirt
05-03-2009 07:17 PM
Roadrage
Ninja ZX-10R
04-09-2008 07:55 PM
DeFran
15
06-05-2007 12:32 PM
c10
08-02-2005 10:08 PM
Eklipse636
07-27-2005 02:08 AM
Quick Reply: tires
