sounds like head gasket
Old May 27, 2007 | 02:06 AM
AzzDawg's Avatar
Default RE: sounds like head gasket
see what i mean, he knows what he is talking about lol
Old May 27, 2007 | 02:52 AM
fewdecentwords's Avatar
it was pretty cold. when i took the comp test. i dont have a gauge i had a friend help me.
Old May 27, 2007 | 12:06 PM
05ZX6R's Avatar
ORIGINAL: fewdecentwords
Doing the compression test without the engine at full operating temp (170 +/-) will not show a bad head gasket. When the block and head get hot and start to warp a little, that is when you need that head gasket to seal properly. Try the test again, a compression tester is about $40 and the best money you can spend. I bet if you take off the head, you will see hairline cracks at the piston rings of the gasket.
Old May 28, 2007 | 05:12 AM
ok so im pretty sure im gunna work on it. so your saying its probably just the gasket then?
Old May 30, 2007 | 08:14 AM
speedracer138's Avatar
I would strongly agree with the head gasket. Take the cylinders off too and check them for corrosion at the base gasket area. You can also look in the cylinders with the spark plugs off to see if there is any coolant in the cylinders/ on top of the pistons. If you try to starttheengine with the plugs removed, you will see coolant spray through the plug holes; then you know it's the head gasket.
Old May 30, 2007 | 03:07 PM
Bluebeast's Avatar
+1 on what speed said. just don't keep cranking the bike over because you might cause more damage to the bike plus kill you battery at the same time. let us know how the repairs go to your bike.
Old May 30, 2007 | 03:28 PM
Notstock's Avatar
Head gasket is a pretty easy fix. Just hope its not the block [:'(]
Old Jun 2, 2007 | 12:13 AM
is it easier to take the engine out and do it or just pull the head off when its still in the frame?
Old Jun 2, 2007 | 01:35 AM
Bluebeast's Avatar
you might be able to do it in the frame. that might be easier then having to life the motor back in the bike. but i'm sure someone esle would be better help on this then me since i've never changed a bikes head gasket.
Old Jun 28, 2007 | 02:54 AM
so i started to work on the bike after a long wait. i was going to sell it but the deals kept falling threw. so ive got the valve cover off and the plugs out so far thats about it. besides the obvious to get to that point. does anyone have any pictures of taking the head off? ive got on but its for a differnt bike. i know that you have to loosen the cam chain and takes the cams off. and you also have to get it top dead center then mark the cams. but is there somthing that i am missing?
