sounds like head gasket
Old May 25, 2007 | 05:00 AM
fewdecentwords's Avatar
Default sounds like head gasket
i have coolant in my oil. i drained the oil and filled the radiator and after about 20 minetes water started coming out of the oil drain plug. i just left the plug out and waited. not water comes out 1 drop every 15-20 seconds. any ideas? the biek runs perfectly.
Old May 25, 2007 | 05:16 AM
Default RE: sounds like head gasket
also when i put new oil in and added coolant since it was completly out. the oil was liek chocolate milk color...
Old May 25, 2007 | 05:27 AM
AzzDawg's Avatar
That does not sound good at all. My vote would be the head gasket.
Old May 25, 2007 | 05:38 AM
ya that really sucks dude. im so pissed. i just bought the bike lol. i got ripped the freak opff. i gues atelast i only paid 700 for the bike but still i didnt know the gasket was bad.
Old May 25, 2007 | 05:46 AM
ive looked online on the procedures to replace the gasket. but it was on a suzuki. are they all prety much the same?
Old May 25, 2007 | 06:13 AM
AzzDawg's Avatar
I cant be sure, but it wouldnt be majorly different i imagine.
How far has the bike been?
Old May 25, 2007 | 08:26 PM
is there anythign else it could be. i have good compression. and the bike runs just fine. just cant add coolant lol.
Old May 26, 2007 | 11:20 PM
Crasher986's Avatar
ORIGINAL: fewdecentwords
I'm no expert, but I have seen several motors taken apart, and I currently have my 03 636 motor split to replace trans parts, and I would say that they are pretty much all the same. Probably could do it in the frame, too.
Old May 26, 2007 | 11:36 PM
ya im still thinking about doing it or not. i might just sell it. im still wondering. becuase the plastics are in bad shape and there are odds and ends taht need to be done and i just dont know if i should put the time and money into it.
Old May 27, 2007 | 12:49 AM
05ZX6R's Avatar
If your pushing coolant then either your head gasket is gone or your block is cracked. Does your coolant tank pressurize after running a little, like a lot of pressure not the typical 10-20 psi? If it does, the leak is above the pistons either in the head or the head gasket. If it doesn't you might have cracked the lower block, but that is highly unlikely. Did you do the compression check with the engine warm or cold?
