Rear Suspension adjustment
Old Mar 11, 2007 | 11:05 PM
Default RE: Rear Suspension adjustment
The only problems that I have encountered with spanner wrenches is the lack of room. Tire is in the way, or the hugger, etc. My 06 10r does not include the spanner in the kit either. Plus my stock shock only had preload adjustments and no ride height adjustments. But shims are available for raising the ride height.
Old Mar 12, 2007 | 12:59 AM
hicktown's Avatar
yea my tool bag that the prev owner gave me doesnt have one. ill have to buy one i guess...
Old Mar 12, 2007 | 05:50 AM
speedracer138's Avatar
Look on ebay. There's a guy selling Ohlins spanner wrenches for around $5 starting bid.
Old Apr 10, 2007 | 11:48 PM
saki ridin's Avatar
the best and easiest way to raise the rear end is just have the extended dog bones put in.. easy to install as well
Old Apr 11, 2007 | 01:10 AM
aszrael1266's Avatar
The Dude
your not really going to be able to raise the rear of the bike by adjusting the rear shock. At best when you get the on the bike the shock wont compress as much and i guess in a way keeping the rear higher. remember stiffer isn't always better. You should try to adjust it correctly. Check the sag. how much the shock compresses when your on it. If you can get a friend to hold the bike while your on it and jump up and own on the bike a bit to make sure the front and rear are set correctly. you don't want to have the bound and rebound all messed up from the front to rear of the bike. The whole bike should squat and raise at the same rate.
Old Apr 11, 2007 | 05:44 AM
First set-up you suspension then set you ride height. Go to www.Ohlins.com or www.Sportrider.comfor articles on suspension setup. To set ride height after suspension set-up, you can use the shims to adjust it between the top shock mount and frame. You can use auto wheel alignment shims available at the parts store.
Kourtneyhk
Oct 18, 2009 05:42 AM
hokiepolk
May 3, 2008 11:45 PM
cwgoff
Aug 30, 2006 02:11 AM
incabiker
Mar 2, 2006 03:20 AM
TATTOOZIT
Jul 7, 2005 06:30 AM
