PROBLEMS!!!
ORIGINAL: Notstock
yea you will get a lot of popping on de-acceleration, or is that when your rich [:@] dam someone answer this question.
i believe that's when you're rich, running lean should pop on the gas and idle (i THINK...)
I'm glad to hear that you got it running. Ever figure out what it was? It will sound a little raspier and you will get a little lean pop/ misfire if it's too lean. Usually with a Slip-on you should be OK. Try it with and without the K&N & stock filter and see which it runs better with.
