PROBLEMS!!!
Old Mar 20, 2006 | 05:21 AM
speedracer138's Avatar
Default RE: PROBLEMS!!!
Did you plug in the IAT sensor connector on the airbox after the air filter change?
Old Mar 20, 2006 | 05:29 AM
Odimus's Avatar
I didn't have to disconnect anything to remove the airfilter.
Old Mar 20, 2006 | 05:38 AM
Can you hear the fuel pump run when you turn on the key? Put you ear against the tank to listen. It should run for at least 3 seconds. Also, Check your EFI fuse.
Old Mar 20, 2006 | 05:42 AM
Odimus's Avatar
It runs. It does everythiing it used to before the exhaust and filter swap out.
Old Mar 20, 2006 | 05:51 AM
It ran fine before the exhaust; Is that what you're saying? Has the bike been sitting a while? Is it possible that something got disconnected when you lifted the tank to change the filter?
Old Mar 20, 2006 | 06:10 PM
Notstock's Avatar
ORIGINAL: Odimus
I'm stationed in Spangdahlem Germany; not far from Luxemberg. I'll get a power commander once I get back to the states. I just want to ride the rest of the time I'm here and then it is off to Northern Cali.
Nice spot I was in Darmstadt just outside if Frankfurt back in the day, sure was a fun time. Would be great place to have a bike.
Old Mar 20, 2006 | 10:09 PM
Odimus's Avatar
I put the battery back in and the bike started right up. I left the K&N filter in. How do you know if the bike is running lean? It ran great today 150+ for start of season.
Old Mar 20, 2006 | 10:23 PM
mr2turbo's Avatar
ORIGINAL: Odimus
you can dyno it with an exhaust gas analyzer and you want the air fuel ratio to be right around 13:1
Old Mar 20, 2006 | 10:27 PM
Odimus's Avatar
Will the bike sound different if it is running lean? I will be getting a PC when I get back the states in April.
Old Mar 20, 2006 | 10:34 PM
Notstock's Avatar
yea you will get a lot of popping on de-acceleration, or is that when your rich [:@] dam someone answer this question.
