PROBLEMS!!!
Old Mar 20, 2006 | 10:44 PM
mr2turbo's Avatar
Default RE: PROBLEMS!!!
ORIGINAL: Notstock
yea you will get a lot of popping on de-acceleration, or is that when your rich [:@] dam someone answer this question.
i believe that's when you're rich, running lean should pop on the gas and idle (i THINK...)
Old Mar 20, 2006 | 10:47 PM
Odimus's Avatar
I guess I'm fine because the bike sounds perfect especially with the new Leo Vince.
Old Mar 21, 2006 | 12:55 AM
mr2turbo's Avatar
so it runs fine now? with filter and pipe?
it won't backfire if it's only a little lean, so you could be making less power even with the mods if it's not tuned right
Old Mar 21, 2006 | 09:30 AM
speedracer138's Avatar
I'm glad to hear that you got it running. Ever figure out what it was? It will sound a little raspier and you will get a little lean pop/ misfire if it's too lean. Usually with a Slip-on you should be OK. Try it with and without the K&N & stock filter and see which it runs better with.
Old Mar 21, 2006 | 09:03 PM
Odimus's Avatar
Thanks all...I'm guessing it was a gremlin that was just passing through...
jstroudzx6
Apr 29, 2021 07:31 AM
bmrconstruction
Jan 28, 2009 11:23 AM
problemvulcan
Nov 2, 2005 03:25 AM
Neotrion
Jun 19, 2005 04:09 PM
nemethjames1
Apr 22, 2005 07:50 AM
