Full Exahust Advice
Why a full and not a slip-on? Unless you're racing, save your money for other stuff. Full systems are made for racing and are louder. They cost twice as much also.
ORIGINAL: speedracer138
Spending the cash on a slip-on and suspension tuning is a way to go as well and may even be better jmo
two bros is a slip on anyways. and its half the price of the ak. I really don't think you want to spend 1500 on an exhaust. but the 2 bros, get the pcIII, do a sprocket change, speedo healer and you'll be set.
I've got the akro evo ti and love it make fat H.P. the only thing is it's a little loud for the street.
The advantage of the full sys is the weight diff and you dump the cat so you can use leaded fuel.
usually when you take a exhaust and make it less restrictive, it looses SOME low end torque. I'm talking about like around 3-5k. I would get the pcIII with an exhaust and that would definatly make up for any low end power u lost. but on a 636 i'm not sure what top speed is, but with a -1+2 setup with speedohealer. the bike will top out at 155, fairly easily too.
ORIGINAL: FuryofGreen
notstock, what kind of sprockets do you have and how many teeth on each one? i dont wanna lose top end or low end and its a trade off isnt it?
But the low and mid are sick, 3rd gear rollon and almost nothing will touch it.
Notstock I gree with you if you're looking for maximum HP, but if you want all around performance, the slip-on in a good trade-off. Like you said though, if you make the other mods to go along with it, it'll work good.
I lost some low-mid topend punch when I removed my Race ECU because It also advanced my timing 4 degrees. I notice and miss the loss of the power I had. Bought an Ignition Module on ebay but it was mis-marked. It turned out to be for a CBR1000RR. Anyone need one?
Nate Brand
KX250 & KX250F
Jul 11, 2013 11:07 PM
